The alarm is finally wired, it took me 5 days!! working on it between jobs. Was a much bigger job than I had originally planned due to the taking my time to make sure it was very neat and problems with soft plaster meaning I had a lot of making good to do etc.
Anyway I have a minor issue, I wired an external speaker and when you set and unset the alarm is is very very loud! So loud in fact it will disturb next door.
However in some cases such as the alarm going off I want it to be very loud. Is it possible to program it so that when you set the alarm and unset it the sound only comes from the keypad?
I suppose an obvious answer would be to run the speaker from the siren output instead or do turn down the volume POT to minimum and use a sound bomb, but is there a way I could simply program out the unset/bleep from the speaker?
