    Dismiss Notice
Vertical Radiators
Discussion in 'Plumbing and Central Heating' started by Robbox, 19 Sep 2018.
  1. Robbox
    Robbox
    21 Jul 2010
    477
    Thanks Received:
    3
    Weymouth, Dorset
    Country:
    Couple of questions....
    Flat vs tube? Tube variety seem to have higher output for similar height x width, is there a reason for this?
    Is there a reliability issue between the more expensive makes, like Reina, and the lesser know makes from B&Q etc?
  2. Sponsored Links
  3. Some decorative,designer heat emitters are the work of the devil :mrgreen:
    what's your installers idea on them :?:
  4. Robbox
    Robbox
    21 Jul 2010
    477
    Thanks Received:
    3
    Weymouth, Dorset
    Country:
    ~what's your installers idea on them :?:~ he just thinks they're expensive!
    The way the room is designed makes horizontal radiators a PIA. Basically, it's a dining area with only one suitable wall for horizontals, that is just where the dining chairs go, but two 'dead' areas that would take a vertical nicely.
  5. ianmcd
    ianmcd
    15 Aug 2010
    22,706
    Thanks Received:
    9,121
    Lanarkshire
    Country:
    be carefull which ones you choose as some have baffles fitted and the flow and return have to be specific, if they are fitted the wrong way round it wont work properly. not all are but a lot are
  6. Sponsored Links
  7. Robbox
    Robbox
    21 Jul 2010
    477
    Thanks Received:
    3
    Weymouth, Dorset
    Country:
    My neighbour bought two off ebay for very good price, they look great and so far no issues....
  8. Purpose made vertical radiators are available from many known manufactures,fit many of these and they work a treat https://www.purmo.com/en/products/panels/vertical.htm#tab-technical-data
    Have fitted them In lieu of decorative designer units that did not supply the heat output their adverts mentioned :idea: for decorative products have used genuine zehnder radiators,good enough.
    sometimes expensive is good :idea:
  9. JP_
    JP_
    17 May 2012
    7,660
    Thanks Received:
    446
    Country:
    can't you just turn a normal one on its end? o_O
  10. ianmcd
    ianmcd
    15 Aug 2010
    22,706
    Thanks Received:
    9,121
    Lanarkshire
    Country:
    Doesnt mean that your flow and returns are the same way round
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
