Could some please give me some advise on what the probable cause of a vibrating pipe when switching on the hot tap at low flow rate.
I have just had my Artisan Eurocombi A/23 replaced with a Worchester 29CDI. Prior to the install of the worchester I had no problem with with my hot water at a low flow rate and never experienced any vibration.
Since installing the new boiler, the kitchen hot tap ( 15yr old mixer ) makes a terrible noise and vibrates the pipe when you turn the tap on but not at full flow. The problem does not exist when using the hot water in the bathroom or shower upstairs.
I contacted the installer and he said it was the jumper on the kitchen tap. Unfortunately he was unable to call back today to have a look. Is this the likely cause or is it something wrong with the boiler or installation . Any help appreciated
Regards
Adie
Regards
Adie
