Hi, I have completely stripped out my house and was talked into buying the above system by my Corgi engineer and the Plumbing shop keeper. It was 2200 quid with whole house pipe work and installation was 1400 plus 400 for rad's in whole house.
The Stanton cylinder is in a cupboard in my daughters bedroom upstairs (old cylinder was in this room too) and the Vitoden 100 is in a kitchen cupboard downstairs.
The engineer fitted in late November last year and I have had to have him back 3 times to (1, stop water coming constantly from overflow pipe which comes out onto my drive at the side of the semi detached house) (2, to change a pipe he did not change during installation that started to leak) (3, to refill boiler that started flashing "reset" and had no pressure, I have since learnt how to do this and have had to do it twice more myself, it has happened when I have turned the wall control down past 16 for a period on more than 4 of 5 hours).
He is coming back again this week as I have discovered that if I turn the heating control down past 19 it clicks the Vitoden off and the rad's go stone cold. If I move to 19 + it clicks on and the Rad's go to full temp. I cannot get a happy medium, the house is very hot or cold. Also one Rad only gets warm.
I have a very nosy next door neighbour and she has twice now said to me that the outlet for the Vitoden for releasing fumes (which is in the drive between our two houses) is constantly releasing steam. She is correct about this, no matter what the weather is outside you can see lots of steam when the Vitoden is running. The weather is pretty mild and I cannot see my own breath yet this outlet seems to pump out steam constantly at an alarming rate! I was wondering if this is correct? And do you think I should have concerns about this whole job. I am slightly worried.
