I have a house with a tenant in that has a Vizo 24 boiler fitted. I had a call that the boiler isnt working correctly. Been and had a look and basically on both heating and water, the boiler kicks in and heats up quickly and then cuts, a second or so later fires back up, heats quickly and cuts again.... adjusting the boiler temperatures adjust how hot it goes before cutting. No fault codes showing. I had the boiler system drained and refilled last winter with a cleaner and inhibitor adding aswell as the heat exchanger flushed so It was tip top for the new tenant and typically troubles have arrived 8 months or so later. Blocked heat exchanger? water does get very hot as do the radiators
