    Dismiss Notice
Vokera 28 Linea "kettling" on CH but not HW
Discussion in 'Plumbing and Central Heating' started by kjmcdow, 17 Jan 2019.
  1. kjmcdow
    kjmcdow
    3 Dec 2009
    45
    Thanks Received:
    2
    Yorkshire
    Country:
    Still keepin' the auld 28 going but it's getting noisy when heating the central system; quiet, almost silent when heating water. I suspect the pump is on the way out. Any suggestions on how I check? Would be much obliged for any input.
  2. Sponsored Links
  3. ianmcd
    ianmcd
    15 Aug 2010
    14,057
    Thanks Received:
    4,551
    Lanarkshire
    Country:
    when was the diverter valve last serviced ?
    • Thanks Thanks x 1
  4. kjmcdow
    kjmcdow
    3 Dec 2009
    45
    Thanks Received:
    2
    Yorkshire
    Country:
    The diverter valve was serviced last Autumn but by me, a DIYer. Could I have done something wrong? How do I check?
  5. kjmcdow
    kjmcdow
    3 Dec 2009
    45
    Thanks Received:
    2
    Yorkshire
    Country:
    Is the thinking that the diverter value is not allowing enough flow through the central heating system?
  6. ianmcd
    ianmcd
    15 Aug 2010
    14,057
    Thanks Received:
    4,551
    Lanarkshire
    Country:
    no if everything is working OK you have done it right, not really a hard job, when you say the boiler is kettling is it just for a min or so and settles down or does it do it for a while ? does the boiler modulate to low flame or go off and then come back on ?
  7. kjmcdow
    kjmcdow
    3 Dec 2009
    45
    Thanks Received:
    2
    Yorkshire
    Country:
    The noise is continuous with the CH being on, turn on a tap and its stops, turn off the tap and it starts. Switch to HW only and its stops. The frequency of the noise is also constant.
  8. ianmcd
    ianmcd
    15 Aug 2010
    14,057
    Thanks Received:
    4,551
    Lanarkshire
    Country:
    sorry just came to me, when you serviced the diverter valve did you change the shuttle assembly ? when you say kettling do you mean a high pitched screetching , kettling is exactly that sounds like a kettle boiling
  9. kjmcdow
    kjmcdow
    3 Dec 2009
    45
    Thanks Received:
    2
    Yorkshire
    Country:
    Doesn't sound like a high-pitched screeching more like a pan of water boiling. Could I try uploading a file of the sound?
  10. Sponsored Links
  11. ianmcd
    ianmcd
    15 Aug 2010
    14,057
    Thanks Received:
    4,551
    Lanarkshire
    Country:
    Yes do that but it sounds like you have got it wrong with the diverter valve shuttle replacement, if you only used part of the kit or got the two O rings mixed that would cause it
  12. kjmcdow
    kjmcdow
    3 Dec 2009
    45
    Thanks Received:
    2
    Yorkshire
    Country:
    Can't attach mp4 file, I am afraid.
  13. ianmcd
    ianmcd
    15 Aug 2010
    14,057
    Thanks Received:
    4,551
    Lanarkshire
    Country:
    think you have got the diverter valve service wrong
  14. kjmcdow
    kjmcdow
    3 Dec 2009
    45
    Thanks Received:
    2
    Yorkshire
    Country:
  15. ianmcd
    ianmcd
    15 Aug 2010
    14,057
    Thanks Received:
    4,551
    Lanarkshire
    Country:
    if it stops when you run the HW it is definately diverter valve orientated , that is most definately not Kettling
  16. Hot&Cold
    Hot&Cold
    16 Jun 2017
    1,535
    Thanks Received:
    272
    Country:
    From the short audio clip,it sounds more mechanical that kettling, its almost as if something is bobbin around inside the boiler.
    They are good boilers but at times need an expert to repair them :idea:
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
