Is there any benefit in removing the HW restricter washer that has been mentioned on here before, does it just do the same job as adjusting the tap on the cold water feed?
Thanks,
Andy.
Thanks,
Andy.
Thanks for your reply.
When I turn the inlet tap on full there is more water coming out but its not hot enough, removing the washer would make no difference?
Why do people do it?
Andy.
Sorry Nickso if I have said the wrong thing. My comments were aimed at the OP.
I am of the opinion that if a component is in place, I like to ensure it is replaced (if it is defective). Have been to Vokera with no fan gaskets, bypassed o/h stats etc.
Some of the older boilers use the pressure across that item to sense the DHW flow and removing it completely requires a higher minimum flow rate to start the boiler.
Tony
24S Prisma etc.
The plastic assembly still gives plenty of restriction for that purpose if the rubber has been removed.
Its odd that most boilers have a restrictor but I see them swollen on only a very few models. Never on a Vaillant for example.
Tony
