Hi, I'm new here but not new to DIY. I have a problem with my Vokera 80SP and am looking for info to make a positive diagnosis and then some info on how to fix...
this boiler is pretty much on it's last legs but I need to keep it going for 6 months or so until I get the go ahead on an extension, at which time I will be fitting a new boiler in a new location.
Problem is a lack of hot water from the taps, rads are fine and the gas burner is (currently) working fine. Stuff that has been replaced over the past few years: DHW flow sensor diaphragm, flue pressure differential switch, plus I have cleaned the flue out several times. I don't think any of these fixes are related though, the differential pressure switch was replaced about 2 months ago and this was the last time I worked on the boiler. Also I fitted a couple of new rads last summer and so fully drained and refilled the system then, I did put inhibitor in the new water though.
I can get hot water out of the boiler by closing the two valves (flow and return) on the rad system, so because of this my thoughts are that the diverter valve is the cause rather than the DHW heat exchanger being scaled up. Though could a very blocked heat exchanger cause the diverter valve to not operate? Even with the rad system blocked off, the hot water in the shower is not as hot as it once was...
When I turn the hot tap on, the DHW flow switch operates the lever as it should and the lever looks to operates the diverter valve and the DHW micro-switch, and then the fan operates and the boiler fires fine... but still no hot water. Putting my hand on the rad flow pipe shows that this pipe gets hot, though not very quickly. I kept my hand on it for a minute or so before I got bored.
Let me know if you need more info to diagnose??
on fixing the diverter valve, a refurb kit is peanuts so I was planning to get in there and fit new bits. No-one has serviced this part for at least 4 years.
So, is there an exploded diagram of this anywhere that would help me understand how it works and what I should be looking for.
and/ or, are there any instructions I could use to help me
this job looks a lot more involved than work I have done before on the boiler so any help or advice is appreciated.
thanks in advance,
Drew
thanks in advance,
Drew
