Vokera Excell SP80 Heating but no hot water ???.
Sounds like it
Is there continuity between black and white with the switch at rest and with it pushed in.
Scatmanjohn
When probing the black and white wires i get no continuity when the switch is at rest.
When probing the same wires i do get continuity when the switch is pressed.
No continuity across black and red regardless of switch position.
mickp1
thanks scatman,
so i have the exact problem did you guys ever sort that boiler out?
cheer
If the gas valve has been replaced, I would suggest the low burner pressure needs to be checked.
Hey there
thanks
i sorted it out
the low and high gas pressure was right, it was a check valve which conected to the heat exchanger was blocked.
thanks for your input anyways.
cheers
jose
