Hi guys,
I seem to have a fault with my vokera linea 24 combi, which is that when I turn on my hot tap the boiler isn't igniting thus giving cold DHW. The boiler light stays green but when the water is demanded it flickers red then back to green. I carnt say what the code is as it is very quick. If I catch the code I will post it...
Have any of you had this problem before and can assist..
Thank you
P.s this is intermittent and is rectified by turning the white dial to the off position then back on. Also just turned the central heating on using the thermostat in the hall and it still hasn't fired up....
Thank you
