The circled item is known as the flow manifold. When the pump runs, differential pressure is created in the flow manifold resulting in the spindle pushing out and activating the microswitch. The microswitch operates the fan.This only happens when the hot water is turned on.
You will be modifying correct boiler operation which is forbidden under GSIU regulations. What if your gauge is defective and that manifold is bridged out or padded, burner fires with no or little water into the appliance. You then have a fire in the manifold that melts everything. You do know the smallest Linea is like running eight 3 bar electric fires.Can the micro switch be set in the worward position with some scotch tape so error 4 is bypassed? Is this dangerous?
Would Vokera help - this is 20 years old boiler?
Thanks for any help.
Hi,The circled item is known as the flow manifold. When the pump runs, differential pressure is created in the flow manifold resulting in the spindle pushing out and activating the microswitch. The microswitch operates the fan.
The flow manifold operates like this every time the pump runs and pump runs for both heating and hot water demand so to say boiler is more reliable during hot water demand may suggest there is another issue brewing up in the background since during the hot water demand the differential pressure in the flow manifold is weaker.
I suspect the boiler is lacking proper service protocol
Yes, agreed. Bad idea. Need to fix it properly.You will be modifying correct boiler operation which is forbidden under GSIU regulations. What if your gauge is defective and that manifold is bridged out or padded, burner fires with no or little water into the appliance. You then have a fire in the manifold that melts everything. You do know the smallest Linea is like running eight 3 bar electric fires.
Vokera will help if you have a Gas Safe number
I never had to do that as I service and repair boiler. More than that I cannot say.Anyway the question still stands: Do I need to replace the complete part.
What do you mean by that. That you do reguar servicing of your boiler so it doesnt come to problems or what? Please emaborate.I never had to do that as I service and repair boiler. More than that I cannot say.
Not my boiler- I don’t have that boiler. Service this make and model regularly. Minimum for me is what the manual asks under service heading. I prefer to go beyond the minimum requirement. Not the first the have I taken the fan out and washed it, same main heat exchanger, scrubbed the fins and washed under tap, remove burner- examine and clean.. base if chamber is washed and cleaned till it is shined again. The part in your picture is stripped, cleaned, lubed and worn parts replaced. Oh- expansion vessel pressurised.What do you mean by that. That you do reguar servicing of your boiler so it doesnt come to problems or what? Please emaborate.
