That would be the general idea?Also, it fires up when I turn the cold tap on!
I don't think the boiler should fire up when I turn the COLD tap on, like just to fill the kettle ..
If it's just a Linea, pre-heat can't be turned off. If a Linea HE then the pre-heat will only work when in Winter mode.
Still not sure why it fires up every time I run the cold tap though ..
Cheers.
pre-heat certainly can be turned off on the linea 24-28 and 7 series. remove one of the main board jumpers.....jp9 off the top of my head.
I there were a dead leg, how would this be causing the boiler to fire up when I turn a cold water tap on ?
Many Thanks,
Russ
