Vokera maxin 24e cutting out.
5 Jan 2021
Hi i was wondering if anyone can help shine a light on what is wrong with my boiler (vokera maxin 24e). I've had 2 plumbers out and both have been unable to locate the fault. Whenever I run the hot water in the bath the water is luke warm and the boiler keep cycling from pilot to full burner repeatedly. But when I run the hot water from any of the sinks in my flat the boiler fires up the burner and stays on providing very hot water from the taps at the sink. I've managed to obtain hot water in the bath by turning down the cold water inlet valve to the boiler but obviously that's caused my hot water flow rate to drop massively to the point where my bath takes almost 30 minutes to fill. I realise it's an old boiler model and I should invest in a newer boiler but as a new homeowner I don't have the funds to do so.
