I have a Vokerra combi. The central heating is working fine. However, its taking the hot water a while to heat up. It reaches temp after about a minute. Been like this for a couple of weeks.
Put the C/H on and its fine. Radiators are nice and hot. Turn off C/H and they stay cold.
Run a hot tap and after a few minutes its hot. I have felt the C/H pipes when running hot water and they stay cold (amazing what you can learn on this site)
Could it be a faulty electrical thermastor (thing)-oops
Could be, but unless you are in front of it it is hard to inform you precisely. Can you check resistance values etc. Could also be simple as in gas pressure has dropped due to govenor fault. I would recommend a pro visit you.
