- Joined
- 27 Sep 2004
- Messages
- 1,300
- Reaction score
- 83
- Country
Hi, just installed a 6 foot Thorn flurescent light fitting in a workshop which is fed from a house near by. Now when ever the chopsaw is powered up (its only on a 13A plug) the flurescent turns off and then on again a second after once the saw is up to speed. Also the planer causes this to happen. The welder does not however even on full heat.
Could this be due to volt drop?? (I havn't calculated what volt drop I would be getting yet as I will need to go back to check length of run and cable size.)
What is confusing me is that the welder doesnt cause it to happen..,, unless its something to do with the inductive load of the motors on the planer and chopsaw??
All help will be greatly appreciated. Thank you!!
