never used one
Ok. Well as a safe guide. What is the recommended safe distance between say a light switch or plug for drilling? I know not to drill above a light switch or plug but what about sideways?
Not there either, although you should be able to tell which way the cables at least start heading off..I know not to drill above a light switch or plug but what about sideways?
I also have a (not cheap) Bosch one which, similar to what you say, doesn't seem too bad - probably more-or-less 'as good as could be expected'.I've got one. It seems less unreliable than cheaper ones.
I wouldn't personally say that one should never drill into a 'safe zone' - but one certainly should be aware of the greater risk of hitting a cable in a safe zone than elsewhere, and hence do all one can to identify any such hazards. Some rooms (particularly kitchens) can be so littered with 'safe zones' that there are not too many other places to drill!Not there either, although you should be able to tell which way the cables at least start heading off..I know not to drill above a light switch or plug but what about sideways?
That's one of the problems - you would not necessarily know, since it depends upon exactly what the drill had done. It might result in something tripping (or a fuse blowing) when you restored the power and/or something might have stopped working. However, there are also many possibilities of potentially dangerous cable damage that was not immediately or obviously apparent.Ok so assuming you shut the power off and drilled into a wire not knowing and then put the power back on. How would you know if you drilled Into the wiring or not? ... Not that this has happened but this is a concern of mine.
