voltage check
15 Nov 2009
My central heating boiler has gone off (no power) and the book asks if there is 240v present at the boiler. Would you recommend i use my multimeter to do this ? I don't really want to phone an electrician out if its simply a fuse to replace, The fuse in the spur is ok but don't really want to open the boiler up to check other fuses unnecessarily. Ta in advance for any advice. P.S. I'm not at home at the moment so its not an emergency.
Your multimeter is just the tool you require. Set it to AC voltage and measure between L/N, N/E, L/E. You should get around 240v on the first and last.
Bear in mind that when you open the fitting it is live. It would also be wise to test your multimeter on a known working circuit first to make sure the multimeter is working.
Is the boiler on it's own circuit ? if so check mcb / fuse at board.
If it's a spur off a ring, does the rest of the ring circuit still work ?
Have you tried changing the spur fuse (having checked it's a good un with the meter via continuity) ?
If you feel safe to work live and understand the risks, having sorted out the above you could check for L & N at the load and supply side of the spur. If they both work, then check the boiler.
