laptop psu ac cord and fuse help
  • Thread starter Thread starter ih
  • Start date Start date
ih
4 Nov 2006
London
my laptop cloverleaf cord with following spec had ac cord burn out(neutral) hence the 5 amp fuse was not blown (my assumption) the cord was .75mm. the psu is input 100-240v 1.2A 50/60hz and out put 19v 3.42A. The psu is ok as i have checked with multimeter.
My replacement ac cord is .50mm with 3amp fuse will this b ok if not what thickness cable is the correct one and does not fry up. thanking all in advance. kindly note i am not an electrician. i hope it is in the right section.
The power supply is only 65W, which is under 1/2 A at 240V. The new cord will be fine.
Most likely the old cord failed because it was defective from the start, or had failed after lots of flexing near a stress point (they tend to go where the enter the moulded on plugs). If it was a cheap cord, it might not have had much copper in it at all.
  • Thanks
Reactions: ih
the replacement is from the local shop but the cord is still made in china like all the others!
