I'm finally getting around to tackling the problem of pairing a non-Vaillant unvented cylinder with a 438 boiler. The goal is to be able to reduce the flow temperature during the summer, but have the cylinder heated at MAX temp (80 degrees being the default, I think).
I had a previous post on this and was given some useful info:
https://www.diynot.com/diy/threads/vr65-with-on-off-heating-and-hw.388359/#post-2986084
This indicates that the VR65 (or VR66) relies on an appropriate Vaillant ebus thermostat/programmer to control timings for HW.
However, is it the VR65 which instructs the boiler to increase the flow temp to 80 degrees when the 240V cylinder thermostat terminal is closed? And will it do so without the corresponding vaillant controls attached to it.
If so, would it be possible to link the HW zone valve SL to the CYL terminals, which would allow me to use my existing programmer for HW timings and the existing cylinder stat and overheat stat in the Megaflow, and have the VR65 instruct the boiler via ebus to boost the flow temp whenever the CYL terminals are closed?
