vw golf sdi wont start!!!
20 May 2011
I have a Vw Golf sdi 2003 model.Ive just had the fuel pump repaired and it ran fine 4 around 60 miles and then just cut out. Ive put it in a computer and no fault codes ive checked the relays and fuses-- all good. Its doing head in!!!! any ideas?????????????????????? what else to check or try????????
1. Make sure you have diesel to the injector pump with no air bubbles in it.
If you have air in the pipes it wont start.
2. Also check the wiring loom going to the injector pump for bad connection.
3. If you have diesel going to the injectors it should start.
loosen an injector pipe and crank it over and see if you have diesel.
4. It should start with one pipe loose, so try them all one at a time to make
sure its not air locked.
Thanks ill try that on Monday, I'll let u know.
