Having seen the speed of these wagos, im looking into them, i was however going to use the junction box method as all the floor boards are up and i have easy access to the lost to lay wires.
so in a junction box method where you have in and out loop to the next box switch and light fitting wire.
With Wago is it just the same ? Ie there are four terminals in the junction box with "x" amount of wire in each? there for you buy wago connectors with the correct amount of holes ?
