Hi all,
I'm (still) planning on putting a door from my house to my garage but am worried about what exists in the wall. I haven't found any electrical currents with my detector but it is picking up a constant reading of metal throughout. I'm guessing that this is the insulation boards that have the foil outer (what else might give a constant reading across the whole wall?)
The wall in its entirety seems to be 13" thick. The blocks in the garage are 620x210mm (size of the block face) however I've got no idea of the thickness or how the wall is constructed. My novice thought was that it was blockwork with a stud timber frame stuffed with insulation boards, then plasterboard (a guess based on other walls) however I think it may be blockwork/insulation/blockwork/plaster. Does anyone know what the standard construction for this wall would be for a new build?
I've asked Barratts and they said "The homeowner will have to carry out their own investigation, however the make-up of the wall should be blockwork with insulation to the habitable side" - either the blockwork or the insulation is very thick and this goes against my theory of blockwork/insulation/blockwork.
Any info would be helpful as I don't want to wade into the wall thinking I've got a nice thick block to cut into only to find it isn't and I've gone through a pipe!
Also, can anyone recommend any decent builders in the Coventry area in case I bottle it?! No one seems to get back to me
Thanks.
Thanks.
