- Joined
- 15 Aug 2014
- Messages
- 22
- Reaction score
- 1
- Country
I am hanging a run of 1500mm units 2 x 600 and 1 x 300 wall units in my utility room. The wall is unfortunately one of those Thermalite walls which separates the house and garage. There's plasterboard to finish with about 10mm gap between the two. I have decided to use a continuous rail to hang the units on and am putting beefy plugs and screws every 3 inches or so. I have calculated the height to ensure they are where the need to be. Unfortunately (again) the part that I am drilling into has ended up on the horizontal run of the mortar. Chances are this is actually going to be stronger than the meringue like blocks - but am I potentially risking other issues such a cracking to the wall? I am limited in dropping the height of the units down as I have plug sockets below so could only drop another 12mm...
