Kitchen Larder Cabinets not Plumb with wall
6 Feb 2014
Newport, South Wales
Hi all,
Apologies if I am not in the right section, please advise if not.
I am fitting a kitchen and the first problem I have encountered is not unusual but is causing me some grief.
I have quite a few base units some standard height some tall (Larder, integrated Fridge, freezer and cooker). My walls are not plum. Floor is level so plenty of adjustment with the feet. My problem is that at the top of the tall cabinets when level there is a gap of approximately 15mm. This is going to create a knock on effect with the wall cabinets.
I am familiar with scribing and cutting the cabinets to fit but this would mean I would have to do it with every cabinet and there are 12 base units. That’s a lot of cutting. Then there is a problem with aligning the wall cabinets.
I would like to ask how the experts would approach this task?
Thank you in advance.
Bison
JohnD
Party? What party?
15 Nov 2005
South
Cook Islands
If you are using the adjustable cab hangers that have a sort of hook, consider fitting cabinet hanging rail along the entire wall. It is very strong and easy to level, and you can move your cabs along if you get the whim. Its length means you don't have a problem of fixing screw that want to go into a soft mortar joint or a cable, you can just screw a few inches to the side. You only need to get the rail right, and all the cabs will follow.
If your walls are not plumb you could pack out the rail where necessary and screw through the packers. The hangers screw in and out a bit but I don't know if it's as far as 15mm.
rail
hangers
16 Jun 2006
London
Surely the gaps will only be visible on the end units? As others have suggested, can't you use end panels or do the units at either end have integrated end panels?
The wall units can be packed out at the tops (using the rails recommended by JohnD- they cost a couple of quid from screwfix for a metre ) and you can glue packers to the lower backs of them to prevent tilting.
Additionally, if you are tiling, you can pack the tiles out to hide any gaps that might be visible in the area below the full length cabinets where they butt up to the wall hung units.
Photos might help.
16 Jun 2006
London
DIN rail might be the same, I don't know.
I get it from kitchen fittings merchants, I'd guess it is about 2mm thick. I like a long enough piece to do the whole run, it's sold in 1m, 2mm and 3m pieces
https://www.ebay.co.uk/itm/Kitchen-...944205&hash=item27e300b8cb:g:zIgAAOSwz71ZVPxg
*blushes*
I intended to post a link to the rails that you are talking about rather than a DIN rail- senior moment!
That said I will check to see if they (DINs) are interchangeable.
Like you, I too prefer using one length, especially when working on stud walls or walls where the supplied mini rails don't allow you to get a decent fixing.
************edit
This person used DINs
https://www.screwfix.com/p/hylec-35-x-7-5mm-din-rail-1m/6461g
as did this one
https://uk.rs-online.com/web/p/din-rails/0467416/
BUT.. not all DIN rails are equal
https://cdn.automationdirect.com/static/specs/dinrails.pdf
16 Jun 2006
London
Good luck Bison
Please let us know how you get on.
Your feedback may help someone else.
