Hi,I've got two walls to line with wall doctor lining paper,the other walls are lined with normal lining paper,so the finish is the same will it be ok to line over the wall doctor with normal lining paper
Because the two walls in question have some nasty cracks in them and the wall doctor is supposed to be stronger,and the other walls in the room are already lined with normal lining paper
