i've moved into a new property. i want to replace a wall lamp but not sure how to do the wiring. i have 4 wall lamps in the same area which don't work. behind the lamp i want to replace i have 4 cables, 2 of which are earthed. i have no idea where the cables go. i'm asuming they lead to the other lamps. if i try and explain how the wires are currently wired i might confuse you, so if you explain wot to do from scratch i'd appreciate it.
thanx
thanx
