wall lights
Status
Not open for further replies.
21 Mar 2007
Durham
removing ceiling light and replacing with 2x wall lights operated by one switch and need little advise:
will have 4 cables to terminate at light one :
line in / line out / switch / feed for second wall light.
cable is 1.5mm
originaly planned on a rose to wall but now thinking space would be a problem is chocbloc acceptable? or a better method?
would a minor ins cert be used for this?
Will be a bit tight in a fitting, can you run all the wires to the light switch?
MWC yep.
Status
