Evening forum
Just over 2 years ago I had a Wocester green star junior 24i boiler installed. It was a direct replacement for the old one so no moving pipes etc.
I got a friends uncle to do it who've been in the trade over 40 years, all gas safe registered etc.
All fine and working well so I got a chippy to make a cabinet to house the boiler, with room top and bottom to adjust pressure/get to the magnetic filter cleaner etc.
Recently when I was adjusting the pressure though I noticed the wall mounted frame was about 5mm from m the wall. (See pics below taken from above the boiler looks big down)
I phoned the guy who installed it and raised my concerns and he said he'll come out on Monday and have A look - but there's a screw in the middle and others on the wall mounted frame holding it into the wall.
My concern was the fact that one of the screws had completely gone through the rawl plug.
Since the boiler was installed it's been boxed in - if the boiler frame is put right (ie flush to the wall I'd imagine the whole boiler will need to come off which would mean to get access the cabinet would need to be dismantled and all the pipes reattached and it tested for gas safety.
Surely the installer should then foot the bill for a new boxed in cabinet as I had no idea anything was wrong (and had no reason to be) when I paid out for the chippy to make the cabinet.
The boiler doesn't seem to move at all (not that I've tugged it!) and I've since had someone from Worcester out to have a look at the flue who didn't mention it.
Or is there a simpler solution like strengthening with corner braces/brackets so the boiler doesn't have to be moved and the structure dismantled?
I think the chippy said the side panel (by the patio door)can pop off if need be without dismantling the entire frame
Any help or advice would be greatly appreciated. As I said he is coming out on Monday to look at it but I'll probably be at work so will have to speak to him over the phone.
