Hi all,
I am looking to remove an internal wall in my living room, which has had an archway cut into it at an earlier date to enable access between living and dining room.
I am 95% sure that the wall is non load bearing but just need some re-assuring advice before i begin work.
Am i correct in assuming the wall is non load bearing as the wall runs in the same direction as the joists and it would appear the wall has been bricked up to the ceiling after the plasterboard has been put up??
The 5% of doubt comes from the fact that the first course of bricks sit flush with the ground level. Would this just have been done as a guide for where the wall needed to be when the house was first built (1950s) or is this a sign that it could go deeper down to foundation level?
Any help/tips would be appreciated.
Regards
Ant
Regards
Ant
