Wall slightly bigger than plasterboard, how to fill gap.
5 Dec 2012
Cardiganshire
Hi all,
Im going to batten out my external wall and fit Kingspan K18 to insulate the external wall. However the wall is 3.7m long by 2.5 high. 10cm bigger than a 2.4x1.2 board vertical or two boards horizontal across the battens.
Now the manufactuerers recommend leaving a small gap at the bottom of the board when fitting, but a 10cm gap is a bit excessive, so I am probably going to have to cut some small strips about 8cm tall and fill in the shortfall, but im not sure if there is a good practice or best place to do this. I presume I board the wall with the panels horizontal, so do i stick the 8cm tall bit at the top of the two boards, at the bottom or in the middle or once its plastered does it really not make much difference?
silly question i know, but if im gonna do it, I want to do it right :D
thanks
Paul
30 Jun 2009
Londonderry
Generally leave about 15mm between floor level and plasterboard.
If you are fitting skirting boards, then I would fit the 85mm cut a bottom of wall, then if fit 100mm plus skirting, that joint will be hidden.
23 Jun 2013
Manchester
Personally I'd consider filling the bottom with a bit of 2by1. Makes it easy to screw skirting into plus gives a straight bottom edge to work to.
30 Jun 2009
Londonderry
2"x 1" wouldn't be suitable as board depth and plaster will not give you level finish and a lip would be formed by the timber. If a baseplate and well spaced battens have been installed, there will be plenty of secure fixing points for skirting, then there is always a bit of no-nails.
23 Jun 2013
Manchester
okey dokey ;)
