at the moment I have bare floor ready for laminate to go down and plaster board walls. The plasterboard is secured to batons not dot/dabbed.
I need to be able to wipe down and clean the walls and floors as it'll be used for tattooing hence why I want to go with tiles on the walls and laminate flooring for easier cleaning.
What I am wondering is how best to finish the flooring where it would meet the tiles.
Would it be a case of taking the laminate about an inch or two up the wall then tiling the rest of the wall... and then seal the join with silicone sealant?
Thank you for any help!
p.s. I've also considered perhaps laminating the walls with the same flooring. Would this be ok at all? would save money and be easier in the long run if so.
If I can again how would i meet the floor to the wall? overlap and seal?
thanks again!
thanks again!
