Wardrobe feet to help with moving around ??
4 Dec 2006
Kent
Can feet or similar be purchased to sit under the corners of bedroom wardrobes to make moving them easier ??
you can get hard plastic discs, i think they're called gliders, they work on carpets. It seems to be a sort of non-stick material. You may need to sand the feet smooth and clean them to make sure the disks stick well.
If its on wood or vinyl felt feet can be stuck on.
If its carpet you can get gliders.
furniture shop.
i think I might gave got mine in a DIY shed or screwfix.
use big ones if they fit
