Hi all
Should I be worried? our flat roof - warm deck has been built up as follows by our builders and I'm not sure all is as it should be.
From the top of the roof down:
1. felting layer
2. foil backed PIR insulation board (recticel)
3. plywood
4. firings
5. roof joists
6. plasterboard ceiling
My questions are:
1) we have recticel foil backed PIR board - does this include the vapour barrier or is an additional vapour barrier required below the foam board? I've looked at the website and believe the foil acts as a vapour barrier.
2) we then also have 60mm foil backed insulation board fitted BELOW the plywood deck in the flat roof area - there is a cavity below this and then we have the ceiling plasterboard.
Is this going to be a problem in terms of condensation or anything else for that matter or am I over worrying here?
Thanks for any advice !
1. felting layer
3. plywood
4. firings
5. roof joists
My questions are:
