Hi, I hope this is the right place for this. I recently bought a hearth and had it fitted. The hearth is for an electric fire so it's all in one piece and I believe fairly thin as hearths go.
The hearth is in a standard rectangular fireplace. The hearth sticks out 3" and spreads out about 3" wider than the fireplace hole.
We recently noticed that the hearth has cracked and one of the 3"x3" sections is now separated from the rest of the hearth (although not movable).
The break looks like the main hearth is now about 3mm further back than the square bit, which is jammed right up against the wall.
Our best guess is that it happened when my dad shoved a plastic toy box into the hearth (fairly hard). This must have moved the entire hearth back until the corner hit the wall and snapped.
So my question is, should this be possible? The hearth was laid on some cement which I would have thought should have held the hearth in place.
The shop that supplied and fitted the hearth are saying that it's our fault it has broken and I'd like some opinions on whether it was poorly fitted or whether we need to be a lot more careful with hearths in future.
Thanks for any opinions.
