Washing exterior brick wall
2 Feb 2016
I have quite a bit construction dust from cutting tiles and slabs etc on some of my brickwork. Once I’m done I want to clean my brickwork. Is it safe to directly hose down exterior bricks or maybe even pressure wash it?
Yeah.
Companies do it or you can hire long reach kit if you need to
Avoid a hose as that will saturated the wall. Use a jet wash on low pressure and a distance from the surface.
Use a soap product to lift the dust, rather than it get ingrained. Not a normal detergent or anything chlorine based, but either a specific masonry cleaner or a ph-neutral soap as used for car cleaning.
