It's very common in the social housing stock here to have dedicated circuits for the likes of washing machines....and, of course, other items on the circuit - it's unlikely to be a separate circuit for the WM.
When you say "dedicated circuit", do you mean with its own dedicated RCD or RCBO (since that is what would be relevant in terms of the way this issue arose in discussion)?It's very common in the social housing stock here to have dedicated circuits for the likes of washing machines.
I don't think that it's all that strange. If you look at, say, what people drink and eat (or what 'language they speak), there's a fair bit of regional variation just within England!Isn't it strange that different parts of the UK seem to have different ways of doing things.
If you believe in diversity, a 20A/2.5mm² circuit can support an oven/cooker of about 9.9kW - which I would call "fairly meaty" .A lot of kitchens we do are also just a 20A 2.5 radial for the oven. Seems round these parts single ovens are more popular than anything meatier.
Apart from Appendix 15 being only advisory, it doesn't say that.Interesting, I have always said that since washing machines, tumble driers, dish washers, and ovens are all over 2 kW using the advice in the appendix of the BS7671 then they should have dedicated circuits.
Quite so - and, furthermore, what it is really talking about (the fact that it's in App 15 is the clue!) is that, in order to reduce the risk of overloading part of the cable, there are certain high loads (particularly long-lasting ones) which are probably best not connected to a ring final circuit.Apart from Appendix 15 being only advisory, it doesn't say that. .... It says cooking appliances over 2kW which could be why we put cooking appliances on separate circuits. The other stipulation is loads similar to immersion heaters and comprehensive space heating - presumably 3kW and over. I think this has been pointed out before.
I presume that you are talking about the BS7671 definition of "a circuit" - but, if so, and with respect, I think that interpretation is rather silly. BS7671 says that a circuit is an "assembly of electrical equipment .... protected against overcurrent by the same protective device". I think that we (and BS7671) all know what "protected against overcurrent means" and that is does not mean that the residual current detected by an RCD has gone over a threshold!!There is also the fact any RCD measures current unlike the ELCB-v which measured voltage, and it trips when the current goes over the rated value, so it has to be an over current device even if that current is not the current being used. So by definition a RCD creates circuits.
