I took the back off my 23-/24-year-old Indesit WG1130TGT washing machine as the drum was either jerking round or not going round at all. I noticed that the back of the outer drum, which contains the wash drum, had been leaking from around the bolt heads as there was washing powder residue streaked down. The leaked water had run down onto some wiring below it and into the JST spade terminal connector block mounted on the motor, causing corrosion of some terminals and burning of the plastic connector housing, indicating shorting had occurred. Anyway, I've put new connectors on he wires and am going to reposition them, so that problem's fixed. (Btw, there's plenty of carbon rod left in the motor brush assemblies; lack of rod could have been part of the problem, but it clearly isn't.) The question is: What sealant should I use on and around the bolt heads of the outer drum to stop the water leaking? General-purpose silicone sealant? I noticed some kind of aerosol spray leak fixer when browsing but I don't want to buy something that won't work in my particular situation. Note that the bolt heads are rusty.
Above pic showing evidence of water leakage from around bolt heads on back of outer drum.
Above pic showing close-up of back of outer drum with washing powder residue cleaned off, and rusted bolt heads.
