washing machine waste pipe into guttering down pipe ?
2 Apr 2006
Essex
Help please for a newbie :oops:
Would it be possible for me to run my washing machine waste pipe into the same point that the 68mm down pipe from the gutters feed into? I'm 99% sure it is a soak away but am unsure on build regs.
Thanks for any help.
Regards
Mark
you should only run the w.m. waste into the foul water system (sewer), and definately not into the storm system.
as should of said
its fresh water drain not sewer drain ..
go ahead
Find out if your sewers are combined or seperate systems, they speak for themselves, if its combined, then its no prob.
OK, what's the best/easiest way to find out? hose pipe down the downpipe and lift the manhole to check for flow?
Mark
I suppose you could, but you have to flush your toilet too, to see if that runs there also. If it does then its a combined system. To be really sure find out from your local authority
