Waste to soil pipe connection
You need a solvent weld cross - Hunter W574 and a cap W91 . or similar from other makes :wink:
Cheers,
With regards to the swept tee, right or wrong, I think it was there because the waste coming from left to right in the photo is from a shower waste and there is Also a considerable fall between the tee and the soil pipe connection which presumably might help the high flow drainage. The waste on the far/wrong side of the swept tee is from a barely used (once a month) basin in the adjoining room..
You guys will probably tell me it makes no difference right! :?
I should make clear that I didn't put any of this in! It was already in the huse!
It`ll be allright :wink: you`d probably never get a cross from any plumbers merchants anyway - they stock F- alll :roll:
