Hi, we have a large shed which was built before we moved in. The concrete infront of the doors is flat so water pools when it rains and goes under the shed door.
I think I have 2 options:
Channel drain
Use a scabbler to remove layers of concrete.
I haven't used one of these would they be suitable.
I've attached a photo - my other question is if people think I should put a drain in where do I put it - as close to the building as possible (the rest of the flat area will likely continue to pool though?) my thought would be to put it just to the right of the post at the end. The shadow is the overhang so following just inside the line of that.
Thanks for your help
Channel drain
