Water condensation problems in the winter
  • Thread starter Thread starter OM2
  • Start date Start date
OM2
18 Jan 2007
I have a first floor flat - we have single glazed windows
Every winter, we get water collecting around all of the windows
Someone said on double glazed windows, you have a small devise that puts holes in that you can slide left and right - this gives a small airflow that then stops the condensation problem
For a single glazed window, how do I stop the problem??
It makes the whole place look really really bad :(
Otherwise it looks lovely!
OM
I think you misunderstand the problem, lack of ventilation leads to condensation, new double glazed units have a trickle vent to help alleviate condensation but it by no means cures the problem, single glazing is more prone to condensation as it is usually colder than double glazing, so moisture condenses easily.
You should a mechanical vented kitchen and bathroom [extractor fans] and at least one permanently open vent in each room or an open chimney depending on age of house.
Though if you dry washing in the house or don't use fans at every opportunity then it's a pointless exercise.
thanks for the replies
seems as though we have a losing battle :(
come every winter, the flat turns horrible and moldy
one of the causes (which i didn't realise before): hanging clothes indoors
are the damn catcher things any good?
i did some searching and saw some people talking about them
they cost just over £5 each
if any good, how long do they last? are they resuable??
thanks
no
you have to get the water outside your home. A washing line in the garden, or a vented tumble drier will do it.
otherwise, have you got an extractor fan in your bathroom, and does it work?
You will never ever prevent condensation on single glazed windows
What we used to do - in our unheated 1950`s council house - was let the ice form on the inside of the windows , then scrape it off and brush it into a dustpan . That was in the winter of `63 - there`s another one like that coming this year :mrgreen:
We used to jump out of bed to be the first to draw pictures in the ice 8)
No central heating or DG in the good 'ole days. And we were no worse off for it either
if this is a rented flat, or you are not in a position to add double glazing or Secondary Glazing (which can be a DIY job), you might consider fitting one of the DIY Plastic Film treatments, which will only last one year, but are quite cheap and will prevent heat loss and condensation nearly as well as DG. If the old window frames are slightly gappy, this will allow the space to ventilate to the outside, which will prevent condensation or damp inside the airspace.
If you have casement windows, you can apply the film to the casement so that it can still be opened for ventilation (which is essential)
The plastic film adhesives stick best to very clean paintwork, preferably fairly new and glossy.
examples
http://www.wickes.co.uk/invt/210014
http://www.screwfix.com/p/stormguard-glazing-film-tape-kit/98002?_requestid=111060
http://www.diy.com/nav/build/insula...econdary-Glazing-Film-10908059?skuId=11398755
there should be some at your DIY shed or hardware shop.
Boy, that's an expensive cloth.
Which does just as good a job for £50+ less :)
