Water damaged ceiling plaster idea
12 Jul 2011
Stirlingshire
It has been around a month since the ceiling plaster came down due to water damage. Water leak in the loft has been fixed, and the ceiling has been drying for a month.
But there are still the water marks, which might suggest it is not fully dry yet? How long usually does it take to fully dry for these plaster boards? They are very old.
And there is a hole or tear on the corner of one of the plaster boards as seen in the photo. What would be best material to seal the tear or hole? I was thinking of a few options such as masking tape, plaster tape, plaster mesh or strong vinyl duck tape before putting on SBR over them.
Or would it be just better to fill it with base coat plaster, then skim over it? Thanks in advance.
Plasterboard takes a few days to dry out. Any sealer like pva or sbr will work.
You will need to fill hole first or replace plasterboard depending on damage.
Let that set then tape and skim over.
Mesh tape is fine.
Masking tape or duck tape is not the correct products
The damaged area appears to be sagging. If you do not cut it out, press it up against the joists, back into position, and secure it with screws. If it is crumbly, this will not work.
