Water flow rate and unvented cylinder question
5 May 2004
Hi - just realised I need a bigger hot water tank and bigger cold water tank to service our new mixer shower. This has now pushed us into the the realms of fitting a unvented cylinder instead.
However, the mains water feed into our house is only 15mm with a flow rate of approx 12lm out of the kitchen tap and a static pressure of 3 bar.
Is this good enough to run an unvented cylinder and still get a decent flow out of the mixer shower ?
Cheers.
No, the flow rate is too low. Say your shower is 10 lpm (and some can run to 30 lpm), then if its running, there's only 2 lpm for anything else and its not enough.
However, if you really have 3 bar pressure, the low flow rate may be caused by obstructions / restrictions. Test what the pressure is at an "open pipe" outlet, with one other outlet (kitchen tap) running. If its over 2 bar you might be in with a chance after some pipework changes. If your kitchen tap has an isolation valve on it, unless it's a full bore one, it will restrict the flow rate to what 3 bar can push through a 10mm diameter.
ok, ran the kitchen tap and re-tested the water pressure at a nearby outlet - it came in at 1 bar :(
Am I stuck with a vented system ?
Thanks for the replies.
I'm pretty much resigned to enlarging our hot & cold water tanks and then pumping them to our mixer with a twin pump. Looking at approx 200 litres for each tank which should suffice.
Cheers.
So why not have a pressure vessel as Dan has suggested? That'll give you 3 bar hot water at a much higher flow rate than your incoming main
Because my thermistatic mixer needs equal hot and cold pressure
A balanced supply.
If you have a cold water storage tank then removing that in favour of accumulator(s) will by definition result in a balanced supply as that is where you cold is fed from as well as the hot.
