Water found in soil pipe
9 Dec 2022
Hi, have slight issues with water draining away from upstairs shower and the toilets water level taking a bit longer to find it's level after flushing. 2 weeks ago the water company must have been called by someone else in the street and lifted drains and fired water up the main pipes. Now I'm having these issues. I've opened an inspection port on the 110mm which is floor level downstairs and took a picture down the pipe which probably goes down another 500mm before it tees off. The picture shows an unknown level of standing water which is a bit bubbly. I don't know if this water is supposed to be there or not if anyone can shed any light please that would be appreciated.
I have a downstairs wc which is
lower than my inspection port so I'm going to fill the sink and try and record that waste water entre the pipe and see if it drains away. Its very awkward though.
When you say external drains we have 1 drain which is in someone's back garden at the end of the street then drains on the public footpath.
Short answer, no. That water shouldn't be there, and chances are you've a full or partial blockage somewhere downstream. If the Water Co. were Jetting the sewers in street recently, that would be indicative of an issue, it's possible they've cleared something downstream, but the initial issue has caused a secondary issue which is affecting your property. Check external manholes, if they're full then there is still an issue.
If only you affected, then afraid it may be down to you to sort out, if the Neighbours have issues too, then get the Water Co. back out.
