hi all,
right first quest ion is i have electric heaters in all rooms and for water for the pots and a bath a water tank with two heating elements. Now only the bottom one has a wire running from there to a switch on the wall with a red light. The higher element has no wireing from it and to remove the silver cover, nothing seems wired up.
it is a relatively small 2 bed place and is this the normal practice, (built around 2006) that the higher element is not really required, or has this been forgotton? there is a switch on the outside of the cupboard that appears to do nothing?
the installers no longer seem to be available...
secondly i want to fit a timer so have bought a standard st6100c honeywell timer, can this basicly be installed where the switch is or failing that at the blanking plate a little lower in the wall below the switch, between switch and heater? and if so can someone explain the wiring diagram as its live and neutral fed and earther, then the wiring running from the boiler to what will be the timer, goes into which ports and which order?
any help would be appreciated
