Water keeps overflowing into the pan after cistern refill
5 Oct 2004
Essex
My 2 year old newish cistern has had an intermittent issue of water overflowing into the pan after a refill.
If any of the dual push buttons is pressed gently, the overflow stops. One can also hear something snap through a vacuum the button is pressed to stop the overflow.
I am hoping this might be a simple fix. If someone can guide, I would be grateful.
Thanks.
Take the flush mechanism out, they're often on a bayonet type fitting, it may be scaled up.
Or, the cable (if it has one) may have too sharp a bend in it, try and re-route it.
Sorry there is no cable or breakage of any type. Its a push button type, so can't have cable anyway.
It sounds like a sticking valve or a restriction that is disallowing its free movement back to close position.
A lot of push button cisterns are either a cable connection or a pressure tube that connect remotely from the back of the button to the flush valve.
I presume though yours may have a dual button in the lid that presses down, via rods, onto the flush valve below?
You may find that it just needs the rods adjusted, mechanical triggers like these do wear and need periodical adjustment/cleaned.
I do have a dual button that presses down and the underlying movement with rods is all clear.
I suspect something in the flush valve is not moving freely. To stop the water, all I do is press one of the dual buttons gently and I can hear something pop, and water stops flowing in the pan.
