Hi all,
Came into the en-suite where the boiler is to find the floor damp, and a quite regular drip from the bottom of the boiler (Worcester Bosch 30Cdi Combi).
Following the drips up, it would appear that it's leaking from near this plastic piece. If you turn the hot taps on/off you seem to get a little spray by the red arrow, but there also appears to be water in with the yellow arrow, so not sure if it's just flowing down under pressure, or if it's cracked. Turning the cold mains supply off to the boiler stops the leak, so no hot water til Monday.
We previously had a leak from this manifold which turned out to be a washer (and absolutely flooded this room), but I'm guessing that this is probably a bit more terminal as I think it's coming from the plastic itself - the part appears to be about £160.
Guessing this is not a DIY job?
Cheers
Cheers
