Dear all,
Since we moved into our new home (built in 1971), we’ve had nothing but problems with the plumbing, at least some of them self inflicted – to try and keep this concise, I’ll list the problems in bullet point form:
Additional info:
For some reason, the filling loop to pressurise the boiler is remote from the boiler itself. The boiler is in the garage, but to pressurise it you have to open a tap which is directly connected to the heating coil in the hot water cylinder. This is a pain, because you cannot see what pressure you have got to when opening the tap. When the tap is opened, I am convinced that I can hear water mixing –i.e. not just water running through the coil, but water coming out of the coil and into the stored hot water. This would explain the pressure loss, but where would this water go?
After the kids had their bath yesterday, I noticed silt in the bottom of the bath after it had been drained. This is also making me think that the heating coil is leaking and I am getting water from the boiler and central heating system mixing in with the water in the cylinder.
Is there any easy way to test my theory that water is escaping from the heating coil and into the cylinder?
Any help would be much appreciated, as this is driving me nuts! We only moved in 4 weeks ago, and it doesn’t feel like home yet because pretty much all we have done is fix problems (and cause some).
Thanks,
Ackoman
- Screw put through pipe when trying to secure some floor boards – not noticed at the time, because there was no immediate water leak
- Later that day, boiler (Vaillant Ecotech plus 618) not providing hot water to coil in hot water cylinder
- Inspection of boiler showed F.75 error and boiler low in pressure. It may well have been low in pressure since we moved in – we had had no reason to inspect it.
- System was re pressurised and F.75 error went away.
- Overnight, the pressure dropped again
- This then made me think I had damaged a pipe when doing the floorboards, and so it turned out – screw straight through centre of pipe. Did not apparently cause a leak though – water only started to come out when screw was removed. Plumber called and new section of pipe put in to replace damage section.
- Quite a bit of water came out during the plumbers repair, but we did our best to contain it and mop it up. The pipe appeared to be going to taps though, and not central heating, so why would a leak in that pipe cause pressure to drop?
- He refilled the system
- Overnight it lost pressure again and showed F.75 error again.
- Plumber came back twice that week and replaced two (yes, two) pressure sensors in the boiler.
- F.75 error was replaced with a F.22 error.
- He refilled the system, and all seemed well.
- Overnight, the pressure had dropped again though.
- Also, overnight water had been found to have been dripping through living room ceiling, in a place several meters away from where that screw was put through a pipe. i.e. not obviously related.
- Plumber called again – we managed to convince ourselves that the leak in the living room was in fact water from the earlier screw through pipe incident, and there were not any other leaks.
- Plumber did notice a small leak on the PRV, which he replaced.
- The pressure still dropped, but over a much longer period of time (3 days or so).
- I refilled the system, and around 1 hour or so later we had water coming through the living room ceiling again.
- System now drained and I’m not refilling it again until I’ve got a better idea of what on earth is going on.
Additional info:
Thanks,
Ackoman
