Indeed. I wouldn't expect second-hand bathwater to be all that pure, but it isn't correct to say that water is highly conductive when the opposite is true.
What "opposite"? Do you mean when the water is 'pure'? If so, I think everyone is agreed that totally 'pure' water is almost completely non-conductive. However, no tapwater, or water that has come out of the ground, is 'pure'.Indeed. I wouldn't expect second-hand bathwater to be all that pure, but it isn't correct to say that water is highly conductive when the opposite is true.
My point is that it isn't the water which is conductive - it is the impurities. So to say water is highly conductive is essentially nonsense.What "opposite"? Do you mean when the water is 'pure'? If so, I think everyone is agreed that totally 'pure' water is almost completely non-conductive. However, no tapwater, or water that has come out of the ground, is 'pure'.Indeed. I wouldn't expect second-hand bathwater to be all that pure, but it isn't correct to say that water is highly conductive when the opposite is true.
Kind Regards, John
Do we have to?that's before one even considers any other 'body fluids'.
True, but that's a bit pedantic - "tap water" (which, even if not explicitly stated, is obviously what we've been talking about) is not just water - it is "water+impurities", and that is conductive.My point is that it isn't the water which is conductive - it is the impurities. So to say water is highly conductive is essentially nonsense.
What do you mean by "no continuity value measured"? What were you measuring it with and what was the highest resistance it could display?My test show using that using two probes into a full bath of potable water, that there is no continuity value measured in my water.
That's roughly what I would have expected - hence my question to PBoD.Well, just for fun I have filled by bathroom basin with cold water from the tap and dipped the probes of my MF tester in and run an insulation test: 0.003MΩ (3KΩ) at 250 and 500 and 1000V.
How far apart?Well, just for fun I have filled by bathroom basin with cold water from the tap and dipped the probes of my MF tester in
Why do you feel that internal pipework needs bonding? Were it not for the almost inevitable 'incidental' connections from pipework to earth (CH components, immersions etc.) it would arguably be safer not to bond/earth internal pipework, when the incoming supply was in plastic, wouldn't it?Is nobody else concerned with the question as to whether there is bonding in place on the internal pipework?
Not when you have metallic pipework extending throughout the house between different locations. Would you really want, say, a damaged kettle flex draped over a kitchen tap to leave all the pipework and taps in the bathroom live?Why do you feel that internal pipework needs bonding? Were it not for the almost inevitable 'incidental' connections from pipework to earth (CH components, immersions etc.) it would arguably be safer not to bond/earth internal pipework, when the incoming supply was in plastic, wouldn't it?
