Water Meter access pipe. Moveable?
4 Nov 2006
Oxfordshire
Hi there, I'm goinng to be laying a new path with a slightly different line that will take it over the Water Meter Access plate. Now I WON'T be inhibiting access as the path is only going to be sandstone slabe and gravel, but I do need to lower the cover plate.
It looks as if it is telescopic,(which would make sense as I'm sure not all meter are exactly the same depth) but I can't seem to budge it, any tips, do I need to dig out around it to create free space? can it be done?
Anytips welcome,
ThanksTOm
The very few i've seen being installed are usually set to the height required and then concreted in.
